Root Casio Blues Themed Rom Updated 5/5/2013
I reboot in recovery mode and I restore the backup but when I reboot the phone stay in the logo of the "Gz'One!!! Now Loading..." I check the phone and is a C771M130.
Is another way to restore the backup??
if it stays in the now loading screen, the system partition has been messed up. there is only two ways to fix this.
when you plug your phone into your pc, do you see the adb come up when booting?
when your phone is booting, do you see a red light flash?
if neithor, then I am sorry to report that your phone is bricked :(
Yes it flash for 1 to 2 second, I install the casio_stock_rom.zip now boot fine I have internet access but no cellular service.
how I can fix the system partition?
I type the adb devices and I get the MEID number
ok there may still be help for you. in your nandroid, can you tell me the name of it, it should model, "BRS-yyyymmdd-time" also, in that folder, is there a image called boot.img? if it is old enough, it might just work with my M100 nandroid backup. The goal of all of this is so that you can do a verizon ota update to M130 so you are compatible with this ROM and stuffs.
and that was made before you installed the ROM, right?
you can use fastboot to install that boot.img, same procedure as the rooting guide. then you can restore an M100 nandroid that I have. Wipe data, reboot. then you should have data. Then fastboot the stock recovery image on the phone, reboot, and do a verison OTA update to M130.
i am testing it on one of my commandos to verify it is M100. then I will post it :)
EDIT: I just tried it by doing a factory reset, then putting it on. It did not work. I'm very sorry, I thought it was stock. Could you send your nandroid so I may find the problem with it? Yours should have just gone on your device.
