So I installed "Catlog" to see if any apps were spamming commands I don't know of. There are none that spam. I just have one issue.
When I have wifi turned off, I get this error
Telephony NotifyServiceState: 0 home
Registry Virgin Mobile 007127 EvDo rev.
A CSS not supported 1
417RoamInd: 1DefRoamInd:
1EmergOnly: false
This command is being spammed every 3 seconds or so only when Wifi is turned off. 3g can be turned on and it will still give the command. It only stops giving the command when wifi is turned off.
Is this something I should be worried about? Is there a way to make it not request the command every 3 seconds? I am imagining that it is making my phone not go into sleep? I am not sure. I just want to be positive that its not an issue. (OCD problem)
1EmergOnly: false
