Not sure what the issue is but I been trying all these different ROMS. MikRunny-3vo-CDMA-v1.06, viperROM_Redline_v2.5_RC2, Xplod_XE_E3D_2.2.1,OTXE+Titan+HD+ODEXed+New+Beats, even Clean Rom 3.0 and a few others.
The only ROM that works for me with no resets is Clean 2.9.5.
I was wondering if maybe there is an update on most of these new roms that I dont have? I like Xplod but after right after I started loading all my apps from TB & everything up. A few hrs goes by then the resets. Mik Runny CDMA v1.06 was oustanding. battery was excellent. Loaded everything up. Same thing. resets after times passes by. All of these other ROMS did the same thing.
I'm aware of the new radio's and such but been avoiding updating if I dont need to (and because of people having issues), although I do want to try Mean Rom.
Any clue as to what I might be missing or causing all these roms to reset? Any help would be appreciated!
I noticed when I try to download things in the market on Clean ROM 2.9.5, I get a "Your device isnt compatible with this device". Although it is. (QIK works on other roms). Would this be a reason???
These are the apps I have and add everytime I flash a ROM
Audio Manager
Netflix
Hulu
AK Note Pad
Ringer Toggle Widget
Roam Control
Handcent
Google Voice (older version 0.4.2.32 since new version doesnt allow option to Toggle on every call...least last time I checked on Evo 4G when I had that phone. although I didnt add on last flash)
Boot Control
Auto Rotate Switch 1.7
Astro
Wifi Tether 3.1
System Panel
Swift Key (older version since it has arrows)
Skyfire
Opera
SD Card Storage Optimzer
Movies
Ebuddy
Brightness Level 2.2.0
Cache Mate for Root users
Battery Indicator 4.0.4
App Brain
Titanium Back Up (full version)
Audio Manager
Netflix
Hulu
AK Note Pad
Roam Control
Handcent
Boot Control
Astro
Wifi Tether 3.1
System Panel
Skyfire
Opera
Movies
Ebuddy
App Brain
