You'd have to reflash clockwork and restore the nandroid then flash twrp and then do another nandroid in twrp to get a useable copy of the rom you want for twrp.
If you're going to root and flash one rom and then be done clockwork is fine. If you plan to flash regularly I'd suggest running twrp. It works better and has more options than cwm.
