Root [CDMA] Can't edit mms settings on flashed boost 3d after update?
xjxason
I got my 3d flashed to boost mobile a while back and i noticed recently within the last month that my phone hasn't been able to send pictures (mms)... I'm assuming because of an update? So I went to to check my mms connection settings and I cant edit any of them, they are all greyed out (name, mmsc, mms proxy, mms port, mms protocol) and they are all switched back to the sprint mms settings. Is there any way I could unlock these so they can be edited accordingly because what's the use of this nice camera if I can't even use it?
Thanks in advance
Thanks in advance
Your spc code should be all zeros since the phone was unlocked to flash it to boost. However when they flashed it to boost they used a boost phone to copy the settings from do you have that phone? If not updating profiles and settings could make you lose web all together. If you don't have the "other" phone I would take it back to who flashed it. Boost uses sprint towers so.a lot of the setting will still be sprint. I've never flashed to boost. But search tool. Will be your friend in this matter there is tons of info on flashing to boost if.not here on xda for sure.
