Root [CDMA] Easy Noob question
dgrobe2112
so.. i have the 1.5hboot.. CDMA is there only certain roms i can choose from?
i currently running Mean Rom 2.4. but i been thinking bout trying a couple others.. such as
MeanROM 4.5
Nocturnals Xi36
Sense 4 villeC3 evo3d odexed
thanks for your help.
Me and you have the same HBOOT i see. Is yours S-on or off? Mine is on. Man...once i get my ROM loaded...imma leave it alone lol.
You can only use CDMA roms clearly and if your not s-off you will be best using 4ext recovery... Dunno why either of you are not s-off its painless...
Int
i just followed the directions on this website. is there something i missed? said optional but recommended. if i am on Hboot 1.5, i have to do some wire trick or something?
If you're happy with what you have right now, just stay with what you have.
But with hboot 1.50, most people find problem especially if you want to flash ICS rom. I did the wire trick because i want to explore the ICS roms.
