TRDownShift
alright.... so, right now im a little freaked out because To begin with I was just fine with HTC sense, but I wanted the system to run faster etc, etc... so I began rooting I started with this tut Rooting Guide: Perm Root EVO 3D with Revolutionary S-Off Method
And followed it to the letter, but for some reason on the forth Hboot it said it failed... but my phone in Hboot said it had S-off etc, etc, I thought i was just going to have to flash the recovery manually... Fine, so I wen the easy route with the "teamwin" recovery and made a "nandroid" or whatever you call it, but wen I tryed to run a "root only" app as a test it said I was not "root' so at a loss as for what went wrong as I had followed every step I pluged the phone back into the computer for a second go at the "Revolutionary" tool wen I did it told me I had already gotten S-OFF and all there was left to do was install the recovery tool... fine... I did so as I wanted to run CyanogenMod So I thought it might make life easier to have both my recovery and my rom from the same team, but this time i made no "nandroid" as i thought I already had made a backup file on the last recovery....
so here I am, CyanogenMod with no root, but, I do have S-OFF... BUT, No nandroid backup..... So... I guess where I'm going with this is "help" >.>....
Thanks for any help you can give, I did try to look at as many guides As I could find but they all seem to tell you what needs to done but not in fact how to complete the steps givin... So I felt a little lost and ended up Just "wingin it"...
Just says "su is up date" wen I start it.
