Oxygen kernel is about is good as your going to get. It's undervolted, has multiple governors...yeah. I think you would be better off just staying stock
I'll see if I can find the link to the Vork kernel though.
I actually found the Vork kernel for it but you need to convert it to CDMA which i have no idea how to do so i think i will just stick with the stock kernel
