OK folks here is a sense 3.5 rom by aamikam.
OP: MikRunny v1.13 - [ Sense 3.5 | GB 2.3.5 | 3/21/2012 ] - [ CDMA ]
Ok guys, I finally made it to the Evo3D...
This rom is based off of HTC Runnymede 1.05.401.4 and the Pyramid 2.08.401.1 with Sense 3.5 and GB 2.3.5.
A really big thanks goes out to Cappychimp and RC-Team for a lot of the added tweaks and multidevice zip, to romanbb for the original tweaks.
Features:
Ext 4
OC
Odex (DeOdex might come later if u guys will ask for it, other wise... its not worth it)
Fully Optimized and tweaked
Zipalign on boot
Defrag DB's on boot
Busybox 1.19.4
Native screen capture
Beats audio, Dolby, SRS, and EQ in music player
SONY XLoud sound engine
SONY Bravia engine
HTC Quicklaunch widget from bliss also added
Unlocked more [COLOR=#F8941D !important][COLOR=#F8941D !important]settings[/COLOR][/COLOR] in Browser
Rosie, Notifications, Lockscreen and StatusBar tweaks changes "on the fly"
Longpress Volume keys to skip tracks when screen is off mod added (Longpress Vol up is next, and Vol down is Back)
Htc Amaze Camera with 3d Video/Images fully working
All Gapps and market apps updated to newest versions
All other stock sense 3.5 goodies included
Known Bugs:
4G taken out for now, once ill get more CDMA things done... ill try 4G again.
No Picture will show when trying to view a picture through FriendStream (this is because we kinda need to live with a diff album version to see 3d images/[COLOR=#F8941D !important][COLOR=#F8941D !important]video[/COLOR][/COLOR])
3D games will probably not work...
Tweaks:
Change Log:
Features:
Ext 4
OC
Zipalign on boot
Defrag DB's on boot
Busybox 1.19.4
SONY Bravia engine
Known Bugs:
Tweaks:
- Settings TweaksStatusbar Options
Clock Options
- Style (show/hide/center)
- AM/PM Style (show/small/hide)
- Color
- Hide alarm icon
Battery Options
- Battery bar (like Miui with settings thanks to pvy)
- Show/Hide
- Color
Signal Options
- Show/Hide
- Text
- Color
- Transparency
Notification Menu Options
- Recent apps show/hide
- Date show/hide
- Transparent BG
- Skins (Stock/Inverted)
- Default to quicksettings
- Customize quicksettings (show/hide)
Rosie Options
- Custom button
- Hide navbar label
- Carousel on/off
- Quick scroll (3d/2d/semi)
- Drawer matrix (4x5/5x5/4x6/5x6)
- Transparent BG
- Depagineted app drawer
- Bliss Rosie
Display Options
- Overscroll settings (none/glow/bounce & glow/bounce)
- Window and Transition animations speeds (6 diff speeds + off)
- CRT on/off
- Unlock animation on/off
- 3D home
- Font Sizes (7 different sizes)
- Auto brightness settings
- Softkeys lights (on/off/always on)
Misc Options
- Lockscreen (Honeycomb/Android/HTC - all on the fly)
- SD crad read ahead speeds (128kb - 4096kb | set to 2048 by default)
- Volume key screen on
- SMS screen on
- Snapshot (enable/disable)
- Volume key to take a picture
- HTC_IME Arrow KB (on/off)
- Beats Boost
- SONY XLoud Audio
Phone Information
- Radio etc.
- Battery
- Usage stats
- Wifi - System TweaksBoot options
- Reboot
- Hot Restart
- Recovery
- Bootloader
- [COLOR=#F8941D !important][COLOR=#F8941D !important]Power[/COLOR][/COLOR] off
GodMode
Mount system RW
Mount system RO
Debloater & Storage space
- Remove system apps (use at your own risk as there is no restore option yet)
- Internal & External Storage summery
Memory settings
- Default
- Free up 50/70 MB
Maintenance
- Clear Dalvik-Cache
- Clear Cache
- Fix Permissions
Enable/Disable commands
- Camera sound (on/off)
- Vibration (default/med/low)
- Ads (hide/show)
Bootanimation
- Disable
- Enable
- Get rid of - Extras for funDownload Center
- Htc hub widgets/skins/apps (make sure to d/l ones for your sense version)
Sounds
- Bootanimations sounds
- Volume rocker sounds
- Screen lock sounds
Themes
- Bootanimations (make sure to d/l ones for your device resolution)
- Shutdown animations (make sure to d/l ones for your device resolution)
- Fonts (many to choose from...)
Change Log:
- v1.13
- Played a little more with compression ratios in apk
- Disabled scrolling cache (should improve overall scrolling in apps)
- Disabled mpdecision and thermald processes (should improve battery life)
- Changed RAM tweaks to be like SuperCharger MegaRAM 2 w/512mb {6,12,75,100,125,150 mb} by def.
- Added gps.conf tweaks (should improve gps lock)
- Added tweak from v1.12 is included ofcourse (Roise Carousel)
- Updated Market and Market apps (FullWipe ver.)
- Themes for v1.12 will work on this
- Update Zip version (NoWipe) must be flashed over v1.11 or v1.12 (dont wipe anything... just flash it)
* For Themers
although all apk are diff all themes that worked on 1.12 will work perfect on 1.13
----------------------------------------------------------------------------------------------------------------- - v1.12
- Cleaned out Rosie from useless pngs (might as well since i was digging in it anyways)
- Added tweak to disable Rosie carousel (thanks ozkaya for the mod... and thank me for adding it into tweaks)
- Must flash over v1.11 (dont wipe anything... just flash it)
* For Themers
MikTweaks.apk and Rosie.apk have changed
----------------------------------------------------------------------------------------------------------------- - v1.11
- Fixed 06tweaks script (i forgot a few lines)
- Fixed the ++ add panel bug (thanks will972)
- Fixed Rosie to be black again (thank will972)
- Ran Image opting in all apks (nice size cut)
- Added a few minor tweaks to build.prop
- Updated Market and Market apps (full wipe ver.)
- Two version are up:
1. full wipe.
2. no data wipe. (will obviously overwrite any existing theme though)
Just flash whichever one you want... i always full wipe, keep in mind NoWipe is best flashed over v1.1 as it is stock to ensure no issues.
The nowipe version will not wipe data but you MUST be flashing on top of a MikRunny ROM (any version is fine)!
* For Themers
com.htc.resources.apk has changed
Rosie.apk has changed
- QHD only version
- Cleaned out a few more things from system/framework code
- Repacked all apks in a new way to try an maximize free RAM
- Optimized all compression levels in the apks
- New RAM tweaks (im seeing over 400 free on avg)
- New DB defrag tweaks
- Added slide to remove single notifications
- Added SONY XLoud audio (in tweaks - on/off since it might be too loud for some)
- Update busybox to 1.19.4
- Now using Anthrax build #15 by default
- Updated Market apps (full wipe ver.)
- Updated Maxthon Browser (full wipe ver.)
1. full wipe.
Just flash whichever one you want... i always full wipe.
----------------------------------------------------------------------------------------------------------------- - v1.07
- QHD only version (since most of u guys like that better, approx 6-7 times more d/l for the QHD version)
- Added back RTL fix
- Added MMS overwifi fix
- Added Mail client showing html mode
- This zip only contain system [COLOR=#F8941D !important][COLOR=#F8941D !important]files[/COLOR][/COLOR]... it will not [COLOR=#F8941D !important][COLOR=#F8941D !important]install[/COLOR][/COLOR] a new boot or a mess with your data, just system.
- If u guys dont need RTL in your personal rom, and everything is running great as is... stick with what u using now and skip this update.
- To flash this ROM you MUST be on v1.06 as is ! (no diff kernel)
--------------------------------------------------------------- - v1.06
- Fixed things all over... long story short... new radio i updated to seemed to mess things up for me... so i re-worked a lot of things.
- 2 flavors to the ROM, WVGA sized widgets and QHD sized widgets
- Added back Roam Only mod
- Fixed a few sizes to align better
- Major cleanup to libs/bin/etc.
- 3g speeds should be faster now due to updated libs
- Fixed 1x/3g to show correct (sprint by def dont have it... so i forgot about it in v1.05)
- Updated ramdisk and libs/bin to new OTA (what ever i could ofcourse)
- Added/changed a few more tiny tweaks that run every boot (not that i think it was needed, but should bring better over performance)
- Updated all market apps
- Over all i think this version is the best stable build so far, so this should be the last time i ask u guys to fully wipe... and will only patch from now on (i hope).
- Flashing this ROM WILL WIPE YOUR DATA to ensure no issues, so make a backup if you need to!
----------------------------------------------------------------------------------------------- - v1.05
- "Sprintified the ROM" (everything is just like a sprint rom minus 4g and update profile, this means that a lot of tiny things changed all over)
- Took out HtcLocations related things (we really dont need it in the US and it's eating up a lot of storage)
- Switched weather anims to the wvga version
- Updated a few libs/bin to the latest OTA (mouch more is really not needed since this rom is not based of off a sprint release)
- Turned off a lot of loggers and debug flags all over the framework/apps
- Added Sony Bravia engine
- Took out googlebackup... it was only messing things up anyways.
- Over all i applied everything i learned from doing the shift rom to this one... and its not a lil bit.
----------------------------------------------------------------------------------------------- - v1.02
- Switched to cgoodman RLS kernel CDMA/GSM (#5 had some issue with wifi drops if im not wrong and other versions of his kernel have been taken out)
- Switched back to WVGA MikRunny files to get rid of most of the test rom apps. (widget are a lil smaller... but feels like u got more room on the screen... so i like it better)
- Fixed EReader
- FIxed all audio issues that were present on v1.01
- Fixed Sprint Vvm (all should be good now... i even got rid of the annoying 9016 [COLOR=#F8941D !important][COLOR=#F8941D !important]sms [COLOR=#F8941D !important]messages[/COLOR][/COLOR][/COLOR]) (CDMA)
- Fixed EPST in dialer (should have worked on 1.01... this time im sure there is no glitches) (CDMA)
- Fixed/Added Weather wallpaper
- Fixed Inverted SystemUI Beats Notification text color
- Fixed Notes widget
- Added LTR fix for arabic and hebrew users (CDMA/GSM)
- Changed to smaller Weather videos
- Added Roaming Guard options to [COLOR=#F8941D !important][COLOR=#F8941D !important]mobile[/COLOR][/COLOR] settings (CDMA, and im not sure how it is on GSM)
- Added Htc's SdCardWizard so u guys can delete files from your sd without needing a file explorer
- Took out Htctwitter and replaced with Twitter market app
- Added more shortcuts to MikApps tab
- Probably more that im forgetting... check the known bugs to see what changed.
- This ROM will NOT get deodexed since there is no need for it... sorry... but u guys can still make themes for it much like its done for all of my other roms.
- This ROM WILL WIPE YOUR DATA, so make a backup if you need to!
-------------------------------------------------------------------- - v1.01
- Fixed boot.img issue i had with GSM version
- Fixed UA-STRING in browser to be HTC Evo3D instead of Sensation XL (for gameloft.com games etc.)
- Fixed effects in album FC (thanks to Will972)
- Fixed all issues DB related (Notes, pulling up names in mms, etc.)
- Fixed Sprint Vvm (CDMA)
- Fixed EPST in dialer (CDMA)
- Fixed Location widget
- Fixed Polaris office FC (Thanks to metamasterplay for pointing me to it)
- Changed to my Music apk from Mikrunny WVGA version (beats now dont need headsets to work, overall better quality i guess)
- Changed audio libs and eq files to better ones (Thanks to mahmoudhafez2000 for pointing me to them)
- Added Mms server editing to Mms (for those of u that wanna change it to one other than Sprint's, not sure it is for gsm)
- Added 1x1 Clock widget (Thanks to mahmoudhafez2000 for pointing me to it)
- Should probably fully wipe... if not dont blame me if your Vvm and/or DB issues are not fixed
- From now on the goal is to only release patches as updates and not full rom that will require full wipe
