pyro_guy0001
Does anyone know how to fix the problem?
I'm running latest ASOB
Found the boost mobile APN I hate how the ROMS are unified but don't support boost mobile all the way.. Seems unfair they could easily add boost mobile APN in the file and boom!
Try this guideI need help to unlock my bootloader on my moto g cdma model with kitkat 4.4.2. And than root it. I will hit the thank buttons
Try this guideI need help to unlock my bootloader on my moto g cdma model with kitkat 4.4.2. And than root it. I will hit the thank buttons its a boost mobile
I'm going to check it on my unofficial cm today see what I can do.
Recovery, Kernels, ROMs and More for BoostMobile (05/04/14)
Recovery, Kernels, ROMs and More for BoostMobile (05/04/14) - Android Forums
is ther any other way to unlock the bootloader its says my device cannot be unlock. can you root it without unlocking the bootloader?
Dude chill I gave u the link of ROMS, kernels, custom recoveries and tutorial on how to unlock bootloader for Moto G and how to apply a recovery and how to get ROOT
XT1028 is verizon and you can't unlock the bootloaderoh its a xt1028 and xt1031 both moto gs
Not that I know of, but the guide I posted has worked for many including myself for the Boost XT1031.
what did you do did you go on the site to get the key or did flash it?
I followed the guide. It takes you to Motorola's site to unlock the bootloader.
okay i did went on there website to get the unlock key but i cant get it.
its has kitkat on it 4.4.2 it had when i gotten it.I followed the guide. It takes you to Motorola's site to unlock the bootloader.
Not sure what to tell you. Make sure you are following the steps using the XT1031 and not the XT1028.
