Root [CDMA] Moto G Stock 4.4.4 and 5.1 Soak Tests {Boost Mobile}
If i do a full wipe, del internal sd n everything would i need to use partition updater before installing? Just got a usb otg cable :) eager to use
Edit: formatted to the bones, didn't have to use updater, ty
Using your deodexed debloated rooted stock ROM and xposed+gravity box, very nice ty. Flawless as usual.
Does anyone have a complete backup of the original Moto G CDMA modem files and such?
I installed MIUI v5 on my phone, now I don't get signal, and says I'm missing my sim card. -_- Even though the rom is for Moto G Falcon...
Then I went back to CM11, and still no signal, and using Stock Rom provided by you now, but still no signal. What the hell is going on?
Wifi doesn't turn on either.
Perhaps I'm missing the files for the wireless signal? I don't know... I'm not exactly a master at rooting/modding phones.
Someone told me I need the modem files for it or something like that.
Hmm, an xposed module can take care of the sim notification. For data are your APN setting still the same? Maybe they got wiped
Use partition updator 2 then flash stock zip 4.4.4 from OP.
After that you need to verify your PRL.
Getting status 7 error.
I have The xt1031 moto g.
I'm trying to flash the "Deodexed, debloated, and rooted Stock KXB21.14-L1.57.
falcon_KXB21.14-L1.57_deodexed.zip "
If your using TWRP, try latest CWM or PhilZ recovery.
So CWM says my device is "xt1034" and that's why above zip wouldn't install. Changed updater script "getprop("ro.product.device") to xt1034 and now its working.
Battery says it "xt1031" as well as computer when the phone is plugged in
You have the wrong CWM. SuperR posted a CWM touch on on of the last couple pages, you should try that.
Here's a question, has anyone successfully set up encryption on the deodexed rom? I tried to in the past twice and it started to boot normally then just hung on the last logo. I'm thinking it probably is due to it being deodexed but I have no clue and was curious to see if it was just a freak problem with me, or if others might've had the issue
