1 1iwilly Android Enthusiast Jul 5, 2012 #1 does anybody knows how to How to remove lockscreen app shortcuts on the HTC EVO 3D
1 1iwilly Android Enthusiast Jul 5, 2012 #3 MahaloCat said: What rom are you running? What type of lockscreen? Click to expand... rom is meanromv4.5
MahaloCat Android Expert Jul 5, 2012 #4 1iwilly said: rom is meanromv4.5 Click to expand... I Believe you can't Customize the sense lockscreen on mean rom. It uses the Apps on your deck and auto populates. Somebody correct me if I am wrong.
1 1iwilly Android Enthusiast Jul 6, 2012 #5 MahaloCat said: I Believe you can't Customize the sense lockscreen on mean rom. It uses the Apps on your deck and auto populates. Somebody correct me if I am wrong. Click to expand... well everything in life has a work around or fixed. here is what i found and works real good enjoy I can
D dgrobe2112 Android Enthusiast Jul 11, 2012 #6 you can change it in meanrom. i dont know about on 4.5, but the mean rom i am running you can. Longpress on the home screen, go to display, and there is a lock screen shortcuts toggle.
