I had unlocked the bootloader on my wife's phone and rooted it. Well, she seen a message for an update to 4.4.4. and now phone is in boot loop. It boots and shows home screen and after a few seconds it shuts down and reboots. Can anyone point me in the right direction?![]()
I can't get it to boot into recovery. To tell you the truth I don't remember if I installed CWM or left it in stock.
it went into recovery and tryed to install package and said it failed sig. verificationAre you able to boot to the bootloader by holding vol down + power when the device is off? If so, press vol down until you get to recovery, then vol up to select it.
I got it back with this thread [BoostMobile Only] Guide on returning to StockOk, since you can get into bootloader, I suggest you fastboot a custom recovery. You can follow the instructions here
How to Install CyanogenMod on the Motorola Moto G ("falcon") - CyanogenMod
Skip to the section "Installing recovery using fastboot"
