J jreuter21 Newbie Apr 7, 2012 #1 When looking at the custom ROM lists, how can you tell if it is for gsm or cdma or do they work both ways? I am thinking about trying mildwild. Any opinions on it or other suggestions?
SUroot Extreme Android User Apr 7, 2012 #2 Oxygen and cm7 which mildwild is based on (2 versions) both have separate cdma versions. Not sure if mildwild has used the cdma version though
