Root [CDMA] Original Factory on hboot 1.5 possible?
Is it possible to do a complete factory restore and unroot on hboot 1.5? I need to return my phone to sprint but I can't find how to unroot the phone and go back to factory settings. Thanks for your help
No a factory reset will reset your current rim to fresh stock and not touch hboot. The HTC unlock works fine so it is a non issue
He's asking if there is a way to re-lock the Hboot, s-on, and flash stock ROM/radio/kernel to appear he never rooted the phone.
Its a yes to all, though I'm not so sure about how to re-lock the hboot.
How are you rooted???? If it is via the HTC dev method, there are instructions on how to that on the htcdev.com website....
