Root [CDMA] Phone stays awake after update
Something keeping the phone awake after I updated to 2.17 , I am rooted and did not take the ota I got the odex file from xda , any ideas ?
You're using the stock ROM, right?
Did you do a dalvik cache and cache partition wipe before flashing the file? If not, backup everything you have in titanium and I'd recommend that you wipe dalvik, cache, and data (just to be on the safe side) and then reflash the ROM. That should fix your problems and then just restore with Titanium.
Thank you I will give that a try , and can I use the nandroid backup instead of titanium . I am on a completly stock rom hboot 1.4 and all I had been looking for was the 2.17 update .
Well, the problem may be in the nandroid. That's why I recommended wiping everything. If you restore the nandroid and everything is fine, cool. But if not, be prepared to wipe everything and reflash the stock ROM/kernel.
