pyro_guy0001
Do I have to enter a number in dialer to do this? The PRL is gone..
If its anything like other CDMA phones (and I'm betting it is), you'll need to have a nandroid of a stock based ROM to do a prl or profile update.
this is a little off topic but since you're changing PRL, im guessing you are trying to improve 3g speeds, this might be helpful. I want to edit the settings you get with dialer code ##3282#. But I can't get my MSL code. Using terminal emulator I use the CMDs "su"(Not sure if this is really needed but i don't see how it can hurt) then "getprop ril.MSL" it returns a blank line. Any idea how else i can get it...besides from calling boost and asking them for it?
