OK - Picked up my replacement.
GAWD sense is terrible.
Will be running junuperbear tonight...
*WISHMELUCK*
:smokingsomb:
*WISHMELUCK*
:smokingsomb:
Hmmm USB debugging wasn't checked. Forgot that HTC unlock also does a factory reset... Grrr.
Don only have Ubuntu....hope I can get this done.
Step 1 | Pre-requisites:
Supported Operating Systems:
We only support Windows 7 32bit or Ubuntu 12.04 (and newer) 32bit, you may use a LiveCD if you have the wrong OS installed natively. Win XP 32bit might work for you but we do not support it as we did not test on it.
Windows 8 (64 or 32), 64bit Windows, 64bit Ubuntu, Ubuntu versions lower than 12.04, Virtual Machines and Mac's will NOT work - we will not help you if you break your device!
Right....can't wait to get home and run this.....
No HTC sync or drivers needed...yeah Ubuntu!
i had to get a replacement phone....old one stopped charging.
It was a release day 3evo so got s-off using revolutionary!
Thanks again for everyones wisdom!
dude -
Feels great. htc unlock and wire trick -
just upped my resume - giggidy
