Root [CDMA] rom trouble
teezy23
Boot loader unlocked phone rooted cwm flashed when I install ROMs it goes thru the process fine but then it stops at the boot logo and just stays there waited 10 min for the ROM to boot up but still nothing anyone have the same problem
Havnt had that problem yet but try a doubble install of the rom and make sure u are formatting data/ cache/ dalvik and system. System is located under mounts and storage
Also make sure u download over wifi or straight to pc mobile data will give u a broken/ currupt zip
Did everything you said but still a no go I can't figure out what's wrong cant install ROMs but can restore my backup every time with ease
If all that fails put the rom and gapps package ( if reqired) in the platform tools.
Open command prompt in ptools w shift and left click.
Boot to cwm and select install zip.
Then select install zip over adb/ sideload
In command window type adb sideload then the first 3 letters of the rom and press tab....it should autofill the rest of the file name then hit enter.
Wait for sideload to complete on comp side then watch the phone do its thing whipe cach and dalvik then reboot
If this fails i am at a loss this method should b flawless
