CAN THIS BE MOVED TO THE ROOT SECTION? Sorry.
Well.. alright. So i rooted my phone and everything was fine.. So yesterday i had to take my phone into sprint for an upgrade so i figured i had to unroot. Well i tried to unroot it. Now im stuck at bootloader s on and it shows RELOCKED. I tried to reboot and it just goes to loader. I cant enter recovery either. before i could via CMD since i relocked my phone >.> so i am just stuck at loader.
OK so.. what i had used to lock was
fastboot oem lcok.. so i looked online for the reverse code and found it
fastboot flash unlocktoken Unlock_code.bin
Then i was stuck at the loading screen and though i had boot loop.. so i removed battery and entered bootloader and i was unlocked. With that being done i now have access to recovery.
Still working it out hoping for some help.
Progress Made--
I was able to restore and i now have access to my phone.
1st attempt- I have tried added the p889img to SD which did not work.
2nd attempt- I tried running RUU and that also did not work. I got the 132 error.
"The rom update utility cannot update your andriod phone"
So im back to where i started with this awful custom ROM
This is what i used to begin with not sure if this is needed or not
http://www.youtube.com/watch?v=PgTV8fOeqwU&list=PLE97A70581E4EB9F8&index=15&feature=plpp_video
Ok so i was looking online and RUU doesn't work with S-ON.. I then began to to look up how to switch from S-ON to S-OFF and now i think in screwed again. I have to downgrade from hboot 1.5 to 1.4 without linux which im not sure i can do.. Any help is greatly appreciated.
Progress Made--
