Root [CDMA] [Rooted] wifi stuck "obtaining IP address"
Putty
Android Expert
Reset router, forgot the network. Changed DHCP settings. PCs and iPad connect just fine. Has to be the phone. Sees it, accepts password, but won't grab an IP.
Anyone?
CleanRom 2.2
Stock dual core enabled kernel.
Anyone?
CleanRom 2.2
Reboot into recovery and wipe dalvik and cache and report back.
Same problem, different phone. Assuming I can get my phone into (and out of) recovery mode (which I take it is device dependant), how do you "wipe dalvik and cache"? Or should that have been "wipe dalvik cache"?
Are you rooted ??
Sorry for not getting back sooner. Turns out my problems weren't anything to do with my phone after all! Thanks for taking the time to reply!
