Log below,
One-Click Root ToolKit For Evo 4G LTE!
Script by Max Lee from OneXRoot.com
Credits go to XDA users sparkym3 and Dan Rosenburg for exploit.
[*] This script will:
(1) root your Evo 4G LTE on ICS
(2) install Busybox
(3) install SU files
[*] Before u begin:
(4) Make sure to read full instructions at HTCEvoHacks.com!
CONFIRM ALL THE ABOVE THEN
Please hit Enter when ready.
Press any key to continue . . .
Rooting...
Start Rooting...
failed on '/data/local/tmp' - Permission denied
link failed File exists
reboot #1 - DO NOT DISCONNECT YOUR DEVICE!
/system/bin/sh: cannot create /data/local.prop: Permission denied
reboot #2 - DO NOT DISCONNECT YOUR DEVICE!
remount failed: Operation not permitted
failed to copy 'su' to '/system/bin/su': Read-only file system
Unable to chmod /system/bin/su: No such file or directory
rm failed for /system/xbin/su, No such file or directory
link failed Read-only file system
failed to copy 'Superuser.apk' to '/system/app/./Superuser.apk': Read-only file
system
rm failed for /data/local.prop, No such file or directory
rm failed for /data/local/tmp, Permission denied
failed on '/data/local/tmp.bak' - No such file or directory
3952 KB/s (0 bytes in 1075144.000s)
mount: permission denied (are you root?)
/system/xbin/busybox: cannot open for write: Read-only file system
Unable to chmod /system/xbin/busybox: No such file or directory
/system/bin/sh: /system/xbin/busybox: not found
rebooting
All Done rooting Evo 4G LTE, check out OneXRoot.com for more cool stuff like ROM
s, hacks, tips, and more!
This is running on my C2D unlocking computer ( I run a phone unlocking) shop.
WinXP sp3
Any help would be appreciated. Its an Evo 3d on stock ICS.
(2) install Busybox
[*] Before u begin:
Rooting...
Start Rooting...
system
rebooting
WinXP sp3
