Root [CDMA/SHOOTER][ROM] Unofficial CM10 for Shooter Alpha
I am on JMZ 9-20 CM 10 build. Awhile ago, I had installed the earlier version and just updated with the 9-20 version. Upon using this build, it ran good but was having problems with sometime freezing up and also everytime I booted, it was always revert back to the stock keyboard instead of the ics donation one I had set. So, I decided to to a factory reset and install the 9-20 version by itself. It ran good for about a day, now it freezes up occasionally, I cannot access the internet via my browsers at times (even though I have a signal), and I have app folder pro installed and I use this to put multiple items in a single space on my homepage. This app Ive noticed everytime I reboot, I lose my settings and have to put them back on my homepage. I have done this like 3 times and everytime I reboot I lose these settings. Does anyone have any ideas as to why this is happening. I started from scratch and did a full wipe with caches and everything and now Im having these problems. The problems have gooten so bad that Ive had to switch back to midnights rom. If anyone has any ideas as to why this happened I would consider trying to use this again. Thanks
Hello,
I'm S-Off currently. I formatted DATA/SYSTEM/CACHE.
Installed CM10 rom, rebooted. Boot loops almost immediately after seeing CM animation.
Any tips?
