Root [CDMA] Stable Roms
pyro_guy0001
What ROMs are worth flashing to latest nightlies or even stable, that dont have much issues i not including the MMS issue
Gummy is great, everything seems to work, even mms with stock messaging and SuperR's fix zip and wifi tether works without any fix. I'm using the 8/22 nightly now. Official Liquid Smooth, OSE, Spirit, Vanir, Ehndroix all work pretty good. The boot issues some of these had are gone now, I've been trying them all.The biggest issues seem to be MMS, which can be fixed and WiFi tether, which can be fixed with WiFi Tether Router app on Google Play.
I almost forgot, Seraph08s unofficial PA Beta 1 8/11/2014 build and the last couple unofficial CM11 builds are good great.
thank you i was looking at Seraph08 post on them. i try them. thank you for your feedback.
im not picky i just get stuck alot and the issues are constant i love Gummy but i want more.. anyways thank you for the feedback:)
That's one I forgot to mention. It's not bad. It has a lot of custom options, but some bugs too. It is pretty new for this device though.
yea ikr good rom i might go back to it when it gets better.. dirty unicorns does work but no 3G and no singal.. but oh well
ima try Seraph08 builds with phantom kernel :)
I'm running the official cm11 nightly with no issues so far.. On 0902.. Did have issues with GPS being touchy on 829 but just wiped then reflashed and restored data from prior backup and all was well..
Spirit ROM is pretty good. It has a lot of customizations but still pretty smooth. It gets better every build. I just flashed Mahdi 9/4. It's nice, lots of options and even has DT2W and S2W/S in the kernel. I was pleasantly surprised. I was just wondering earlier if anyone was ever going to put it in a stock kernel.
Edit: Mahdi has some bugs, DT2W lock screen freeze, dialer, WiFi tether. Maybe more, I had to restore my PA backup to call and order a pizza before I checked everything.
