Root [CDMA] TattooedStock v2.0 (WIP)
Tattooedgod
DISCLAIMER: This is a CUSTOM ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
Whats Working : Everything Should be Working
If you find any bugs please let me know. I will take care of it as soon as I can.
I have to say THANK YOU to SuperR for the great base rom to work from. I'll be working on this rom to improve it. I'll be themeing it but it's taking me awhile to do don't know much about themeing so taking a bit. lol. Working on slimming down the apps etc. On this rom there no nav bar it uses pie control. Have already removed some apps and added a few. Working on getting different kernel for rom. So it would be one install with out having to flash a kernel. Hence why performance control is included. Screen shots to come soon as well. Will be optimized stock version by the end.
Features :
  • PIE Control Thanks to EatHeat
  • Mixplorer for files Thanks to HootanParsa
  • Focal as camera
  • Gallery next
  • LockClock from CM
  • KernelTweaker
  • Faux Kernel Thanks to Faux123
  • MORE to come soon
Changelog :
v2.0
  • Brought Navbar back
  • Using Faux Kernel
  • Added KernelTweaker
  • Removed Performance Control
v1.5
  • Added a different kernel
v1.0
  • Removed Navbar
  • Removed more bloat apps
  • Added Mixplorer
  • Added LockClock
  • Added Pie Controls
  • Changed out stock camera and gallery apps
  • Added Performance Control
Install Instructions :
  • Wipe Factory
  • Format /System
  • Install From SD
DOWNLOAD :
v1.0 Here
v1.5 Here
v2.0 Here
v2.0 R2 trying some different things Here
working fine, but got a question, is there anyway flashable zip for the navbar? not really a fan of pie but otherwise working flawlessly.thanks.
Installing 1.5 now...
Had some FC's with pie on home screen. Can't seem to back out of any apps. maybe I'm not used to pie. had to reboot.
I must be a pie misfit. Every time I am in the app drawer, when I want to go back to the home screen, I keep adding a shortcut to the home screen. I'll need to play around some more.
Overall, seems snappy. nice job.
I think I had fc on boot then was working fine. I'm going to be looking into it soon. If you go into build.prop and delete last line then reboot navbar will return just small piece of code.
Updated ROM to v2.0 the R2 is same ROM but with some different system apps. trying some different programs to see which I and others like better.
the mms app would pop up stopped working on start up but would work fine after that
no other problems that i found
