In a less vague description: You will be able to install customized versions of Android, custom recovery systems (for installing these versions of Android and recover from if/when something goes wrong), custom themes (skins), icons, removing apps you wouldn't normally be able to remove, use apps that require root access, etc.
For a bare novice, I recommend you play with your phone as it is for a little bit first. At least a month. Get used to Android before you start messing with it. Many of us have had Android phones in the past, so we knew what we wanted to do when we unlocked.
