Root [CDMA] URGENT HELP NEEDED !! please please please help !!
invince
I have a gsm s-on evo 3d hboot 1.53.0007 unlocked(via htc dev) and rooted , 4ext recovery....i was on mwakious rom and wifi was giving error...and people suggested me to flash boot.img manually...i did that nothing happened....went to restore nand backup of mwakious with wifi....when i rebooted my phone it stuck on white screen with htc logo...i can't use my phone...cant get past that !!!!!!!!!!!
tried different rom nands ...still no luck....
HOW CAN I BRING MY PHONE BACK,....i can still access recovery !
PLEASE PLEASE HELP ! :(:(:(
I do not know much about GSM phones, so I will see if I can get someone here that does, in the meantime, I would strongly suggest you also post over at XDA as they have a larger GSM base there. see link below.
EVO 3D GSM Android Development
I may not be an expert, but can you do a battery pull and get the phone to go into the bootloader screen? I have the CDMA version, so I'm not 100% sure if yours will do this. You can try accessing recovery from there. It will only work if Fastboot was disabled.
Sounds like you need to go to the HTC dev site and download and flash the stock RUU for your phone. The website is a lil convoluted and confusing so just take your time and walk thru all of the steps. Since you can still access boot loader, flashing the RUU will allow you to go back to square one and start over. Of course you'll have to re-unlock your boot loader and re-root but at least you'll have your phone back.
