When I've experienced this issue its because my wifi module was mismatched with my kernel.I cannot connect to any network. Rebooted, pulled battery...nothing seems to work. Anyone know a fix?
I have a newly rooted evo 3d and am attempting to flash some custom roms, but am getting this wifi data error after flashing.
I haven't installed any custom kernels. The only thing I've done is just flash several custom roms; synergy, viper, etc.. Every time, I get the wifi data error.
I can restore to my initial backup and wifi works just fine, but I want to put custom roms on the phone of course, so anyone have any ideas?
I found out last night that I was using roms/kernels fro the 2.3.3 version of android, theres a new kernel. so if you've updated to the current ota you need to put a 2.3.4 rom on your phone, worked for me!I do have that version.
I have heard of Superwipe, but haven't heard of clean 2.0, do you have a link to some more information or the download?
I am going to flash superwipe right now and test it with a stock kernel and synergy rom. If that goes smooth, I will try to flash the kernel after I verify the wifi is working.
Thanks for your help
this, he's using a 2.3.3 rom with a 2.3.4 kernel, or vice versa, this is what happened to me..I honestly think you are flashing rom for a base that you are not on. Post a screenshot of your software information.
if your bootloader is 1.5 you can not downgradeCouldn't take it any longer, I just had to figure this thing out. After playing around with it a bit more, I found out that people who ran the OTA update can only get custom ROMs based on the 2.3.4 OS instead of 2.3.3.
I haven't had enough time to verify, but I think there is a way to flash the hboot to a previous version that allows custom ROMs based on 2.3.3, which also allows an overclockable kernel.
plz help! im having the same issues with the wifi i also tried to flash the RCREMIX kernel and it failed but now i cannot connect my wifi it just says error. Ive tried everything even a factory restore but nothing, i didnt backup with nandroid i noobed it out is there anything i can do??? can i restore with sum1 elses file or maybe sum1 send me the stock kernell????
To reflash the kernel, you have to boot into recovery through fastboot
