Root CELBfroyo 3.8
I'm hoping the dev gets this option in Nonsensikal soon, otherwise I may have to switch ROMs just to see if I like this.
I don't care all that much about the lockscreen gestures, but in 3.8 Conap added a CPU settings page where you can easily set maximum and minimum clock speed, as well as change the default governor. It makes it easy as can be.
I fell victim to the mysterious notification timestamp bug, as well as an odd trackball notification issue. Restored back to 3.7 and it worked fine again. Could be that enough of the CM source and framework has changed that I need to do a full wipe, so I'll probably check that out if I have a slow day at work.
Also, check out the deskclock app. When you make an new alarm or edit one, you'll notice the ability to have any given app open when the alarm goes off has been added.
