Root Cell and WiFi signal totally dropped since I moved. Even when standing in same room as router
dhabell
i moved from miami to jacksonville fl and ever since I have 0 to 1 bars cell signal. Jacksonville has lots of sprint towers and I live just outside of downtown.
also my wifi signal is one bar even when I stand right next to my wireless router.
WTH?
any ideas?
If running the FA19 update, I would switch to EJ06. I would then find out which PRL is being used in your area. You can either research it on-line then use Monsters method of changing the PRL or your can flash CTMod 2.5 then update your PRL in the phone settings then flash CTMod 3.5 and your PRL will be updated to your area. Either way will work, Monsters way being the easiest.
I don't really see how moving to the opposite end of the state would have anything to do with anything, unless you new neighbors are stomping on your wifi signal cause they're on the same channel.
try changing which channel your router talks on
Results from that app
