Root Cell Signal Bars?
I was wondering if there is a way too have five signal bars on my rooted aria or how would you do this?also change 3g icon?im using cyanogemod 6.0a and android 2.2 thanks!:)
go here...[MOD][12/10] Ultimate Online Theme Kitchen (New Version 2b) --Make your own theme !! - xda-developers follow instructions then go here UOT Kitchen you can change the icons on the status bar works perfect on my rooted liberated and supports cm6
you can see the battery icon is different with color and actual percentage based on charge( you have a choice of over a dozen battery icons and color pallets... i liked the circle one) plus wireless has color based on strength plus many others you can customize the notification drop down as well though the snap shot doesn't show the bottom half due to transparency
