haha Agreed. Hard to believe people can't understand percentages. Maybe the Android should show mah (milliamps per hour) for each instance instead of percentage. Just kidding of course, that would be even more confusing for these average-IQ-wanna-be-nerd-with-a-smart-phone peeps.
BTW (by the way) y'all could try disabling (shutting off) background data, if y'all hav'n trouble with battery depletion rates (battery life):
Settings->Data Manager->Data Deliver->Background Data
Guys, please. It's not helpful when trying to find a solution for the same problem that others are apparently having to have you chime in about percentages. Let me be clear about the problem and maybe you'll understand it. It's NOT just about percentages. When I wake up and my phone has lost about a quarter of its juice overnight (with no interaction on my part), I check the battery use because this doesn't happen every night. THEN I see that Cell Standby and Phone Idle are the two culprits.
I'm sincerely happy for you that you're not plagued with this issue. But please stop making people read through your post when you think you're just being more clever than others. The post is long enough without you being unhelpful (I know, I'm now adding to the length but after reading enough posts about "just turn this off or that off" or "take math 101 and learn about percentages", I had to respond).
If you don't understand the issue because you're not having it, please move on to another post where you can be helpful. This thread is about battery drain and finding out that the culprit is something that doesn't seem to make sense. It's now September of 2011 and it seems that people (like me) are still having this issue. And no solution yet.
and I've even tried to use airplane mode to knock it down some no luck. If I have to root to take care of it I'll be ticked.
