Root cellcom isreal Firmware
jack_jone
i buy Galaxy I7500 from cellcom and after that i update the firmware using Odin Multi Downloader becuase the Samsung New PC Studio cannot recognize the cellcom firmware and now i have the 1.5 Firmware I7500XXIH7 BUT this one let me lose the 3g dose any one have the original cellcom firmware or 1.6 firmware with supporting of 3g on cellcom(tested one ) please
You need to add the cellcom APN in settings -> mobile settings -> APN. Click menu and add APN.
APN: internetg
Username: guest
Password: guest
leave the rest as is/blank. Click menu and save.
thank you very much i will try that ... what about the 1.6 firmware because the Samsung New PC Studio still give me unsupported device ,,, from where can i get the 1.6 firmware please
1.6 isnt released for the galaxy yet. The latest firmware is II5, and there is a link to odin files in the forum - do a search.
Don't bother using NPS if you've used Odin already. NPS is really broken!
i don't how to thank you but in the way if any one have the original cellcom firmware please send it to me because i need the Arabic support and Hebrew
FYI, in Summer 2010 CellCom Israel changed their APN to "sphone" and retired "internetg". This can be tricky as many Cellcom SIMs still in circulation will populate the internetg APN. Username and password on the new APN are blank.
I'm also having some difficulties to reconnect to Cellcom's 3g network
I ve tried both : sphone & internetg Apns but ...Connection failed
Funny because im pretty sure that it was the : sphone/default parameters before.
any idea ?
After about an hour or two of messing with APN settings,
I have managed to connect to cellcom's 3G/2G network. :)
Here are my settings (they work!):
APN: sphone
MCC: 425
MNC: 02
Authentication type: None
APN type: <Not set>
they told me to put in 'default' in the "APN type" field, which did not work for me.
hope this helps other ppl. Enjoy.
Thank you so much, I upgraded my phone with Galaxo and now I have the 3G working. but I still have an insanely annoying problem I can't access the Market or any google app that requires me to log in. I put my username and password and all I get is:
Can't establish a reliable data connection to the server. This could be blah blah blah..
Anyone has any idea how to solve this?
You can call Cellcom to get the APN settings, and you can follow my tutorial (see my signature) to upgrade to 1.6 (Galaxo) and restore the Google Apps.
&#1489;&#1492;&#1510;&#1500;&#1495;&#1492;!
