Does anyone have a shader for GOF2 to use with Chainfire?
I've got it installed and it runs and it's playable, but the astroids are basically invisible.. which makes the first mission impossible.
I believe applying the correct shader would fix this, but I can't find it anywhere.
Thanks for any information.
