I am thinking about acessing the 64 Gb card in the GS3, without messing with **slow** USB, simple wifi interfaces like 'airdroid' (which though fab, cannot do *full* file handling...
) - no worry about heat, I use an ancient switch's heavy metal box as a heat sink!
Is it possible to attach the GS3 as a 'type of NAS' - so that the SD card in the phone looks and works *just like* any hard drive you would plug into win XP or 7 ???
This would mean I can use utils like XnView to rename, edit, replace and search files massively, and also use a program like 'Auslogics Duplicate File Finder' to wipe out the many duplicates I have seen....
No fiddling with your valuable card while getting it out or messing with other complex solutions like microsd to sata adapters and their virtually non-existent support.... :/
