thanks worm. thats a pretty slick site. i couldnt really think of anything i wanted to change right off,so im going to change my boot animation to test it out.![]()
I tried the honeycomb boot and it was kind of wack, so I'd avoid it. I wanted to try the CIA one, just for S&G's![]()
hmm... it dint work for some reason. still have the TB boot animation. what am i missing?![]()
TPS is odexed, correct? Themes/Mods only play nice on deodexed ROMs![]()
I got it to work. UOT kitchen isn't too complicated, but there are a ton of choices. I do have a question. I got the glowing crysis battery:
Version P, Glowing Crysis![]()
I like the look of it, but I want it to always rotate, not just when charging. I assume that there is a way to do this, but I am lost. Anyone have some advice for a noob wanting to learn?
well,i never did get the boot animation to worki did change my battery icon for sh*ts and giggles. neat.
I'm not sure that is possible, the icons simply follow what the phone tells it to do when called. The rotating animation is the charging state of the icons. I don't think I've ever seen an animated battery icon, that moves when it isn't charging.
I wasn't able to change my boot animation with the Kitchen either, even moving it to the right folder didn't work. I did find an app called Absolute System that is awesome though... It has a ton of options that you can tweek
Thanks, I don't feel so bad,now,lol. Ill definately check that app out... Is it "absolute system root tools"?
If you are rooted then you can go HERE and chose one you like. If you're not rooted, I don't know if there's a way. I'm assuming you are as you posted this in All Things Root section.
hmm,i changed my font and that worked fine... but i tried to change my icons,and they were there for a minute,then reverted back to the old ones.![]()
With the phone being so new I'm just gonna chalk it up to the dev of the app not updating it for the TB yet.
I tried that site. I set everything up to my liking, I click "Submit to Kitchen" I wait. Nothing happens. I click Pickup and wait and dont see anything. There are a ton of other files, but I dont know what they are , or for who. It always says 0 in my cooked files, even though I submit to kitchen. Confusing.
