Help Change battery usage on .246
gstjoker
I'm trying to find that option where it let's you change your settings to either:
1. Performance mode
2. Night Time Mode
3. Battery Save mode
Is there anything on .246 that will let me change this? I must not be looking hard enough in the settings.
I don't believe these options are available in ICS anymore. There are a couple ways to regain control however. Smart Actions; and Data usage options in settings. (data usage has some great controls over even individual app use of data)
Personally, I go into each app as soon as it's installed and regulate it'ts data use and sync options (usually turn them all off) in order to help improve battery life.
