Change how wi-fi comes on when plugged into charger?
  • Start date Start date
A
Android Question
Guest
I have the Samsung Note 2 through Sprint with version 4.4.2 on it. Whenever I plug it in to power to be charged (car or home) wi-fi automatically gets turned on and starts searching for a signal. Is there a setting I can change where wi-fi will ONLY turn on and start searching for a signal when I turn it on, not automatically when it gets put on a charger?
Under wifi settings, look for advanced--> sleep policy. You might need to hit the menu key.
