Help Change S-Copy to box shape
Shave
Member
Hi guys,
An added feature with JB was you can hold down the button on the S-Pen and draw around anything on the screen to copy it. When doing projects on S-Note though I like to be tidy and precise. So I was wondering if there's a way to change the S-Pen selection function from Free-hand to box select?
If not, is there a real easy way to edit pics in the gallery?
Also:
Is there a way to select several items in S-Note and move them around the page?
I sometimes find I do a project, and then find out that I need more room at the top, is there a way to kind of crop everything you need to move and just drag it down?
