Help Change weather site
diti87
Hi. I have a HTC Desire with Android 2.2. I use the default weather widget that is with the clock.
Now I want to know how can I change the site that this widget takes the information from. I think it takes from AccuWeather.com.
Thanks.
Thanks.
I'm 99.99% sure you can't. The widget will be hard-coded to use the AccuWeather API, and this will be different for any other site.
