Help Changes to calendar entries
www11
Hello,
I have an unrooted DHD, 2.3.5, and I have been experiencing an issue which is impacting my faith in the default calendar application: Updates to calendar entries, made via Outlook 2007 or 2010, are not reflected onto the device. Adding or deleting entries works fine however.
i.e. steps to reproduce:
1. Create an entry in Outlook 2007/2010
2. Save it
3. Sync mobile device and confirm event appears in Calendar App.
4. Change body of original invite in Outlook 2007/2010 or change the time of appointment
5. Save it
6. Sync mobile device
7. Notice the change is not sync and the original entry remains
Is this a known issue? It's really annoying when I miss meetings as the times have changed or when the body of the calendar invite is not sync'd (updates).
Help!
www11
Bradshy,
I am not using a widget - just the stock HTC calendar application.
Can you confirm that you don't have this issue?
Cheers,
www11
So the problem is the calender doesn't save changes made to entries......
Hmmmm
I don't use it but have you made sure everything syncs properly? Is your wifi on etc...
Have you tried going into settings, accounts and sync, and force syncing calenders from there?
Hmmmm
Yep, tried all that. Even deleted the exchange account, cleared calendar cache, etc. I am surprised that others aren't experiencing this issue.
A similar thread: http://androidforums.com/android-applications/486892-changes-calendar-events-do-not-sync.html
Cheers,
Akshay
