Root Changing boot up sound (help)
I already changed it once. But what files do I change this time now that I already have a? .mp3 and a .bak
In /system/sounds/poweron, you're going to want to change the PowerOn.mp3 file with whatever other .mp3 you like. It also has to be named exactly the same way. I would also recommend you keep the file short, about twenty seconds or so, otherwise it will get cut off when the phone finishes booting up before the soundbyte is done playing :)
Hi guys . I decided to join this forum to ask Artine a question . First of all , nice job on Sleipnir . I just installed the 2 latest version and both are great . However the boot screen sound was removed for some reason . If it's not too much to ask for , can you post it up for us ? It was dramatic and I liked it .
Indeed I can :)
