Changing default ringtone
stupat78
I've had my S2 for a couple of weeks now. I've set custom ringtones for most of my important contacts. What I want to know is how do you change the default ringtone to something other than the crappy preset samsung ringtones. I want to change it to one of my own music files on the phone.
u can also create a folder on ur sd card called ringtones, and drag any ringtone mp3's u want into that.. then go to the normal settings/sound and those mp3 ringtones will appear in the list. this is good if ur ringtone isnt a song, and u dont want it showing up in ur music player
