scotty85
Extreme Android User
i came across the kitchen on the TB forum. http://uot.dakra.lt/
its a pretty slick website,and i wanted to see if it would work with my lil buddy as well. it does.
there are other options-you can change the battery icon,the other notification bar icons,and boot animations. all i have tried thus far is the font,wich definately worked. i used GSB since thats what most of us are on. if anyone is ambitious enuff to try other things,let us know if they work.
screenie:
when you go to upload the framework from the rom,make sure you change to amend scripting or the .zip it provides will fail the signiture verification.
as always,MAKE A BACKUP before making changes to your phone. if you dont like the results,or it plain doesnt work,youll want to be able to go back.
heres how ya do it:
1)first thing you need to do is find your GSB download and extract its files to somewhere you can easily find them. if youre using windows,you should be able to just right click,then extract all. or you can use something like 7-zip
2)read thru the "how to" section
3)click on kitchen
4)go to the "file upload" tab
5)since GSB is a gingerbread rom,go to the "SystemUI.apk upload this file only if you have Gingerbread rom" uploader and click select file. when the box pops up,navigate to the non-zipped GSB folder and into it
go into the system folder,then the app folder,and find the "systemUI.apk" and double click it(or click it,then click open). the file will upload.
6)move the dot on the left to "amend scripting". leave the patch9 autofix box checked
7) chose your features
you can change a bunch of things at once,but i have been only trying 1 thing at a time for example to change the font click the font pack tab,then check the "use this mod" box and the options will appear. check them all out and pick one.
8)go to summary and click "submit work to kitchen". when its done "cooking" it will give you a download link.
9)download and flash in Amon_Ra recovery,i dint wipe anything,but it wouldnt hurt to wipe dalvik cache. if your instalation aborts you prolly forgot to move the dot next to "amend scripting".
10)reboot
screenie:
heres how ya do it:
3)click on kitchen
go into the system folder,then the app folder,and find the "systemUI.apk" and double click it(or click it,then click open). the file will upload.6)move the dot on the left to "amend scripting". leave the patch9 autofix box checked
you can change a bunch of things at once,but i have been only trying 1 thing at a time for example to change the font click the font pack tab,then check the "use this mod" box and the options will appear. check them all out and pick one.8)go to summary and click "submit work to kitchen". when its done "cooking" it will give you a download link.
10)reboot
