Help Changing Lock Screen Items?
patpending
Hi all,
First day with the Sensation - LOVE IT LOVE IT LOVE IT!!
So crisp, so clean, so many advances over my old Desire!!
First niggling question ... does anyone know if you can change the default Lock Screen Items / Apps?
Defaults are Phone / Mail / Camera / Messages...
I've been through all the usual settings areas etc, and can't seem to find an option to change.
Yep, I'm aware there are downloadable lock-screen apps and so on to achieve this, but was wondering if it was at all possible with the native software.
No biggy, but would be nice :)
Hope you guys are all enjoying yours ;)
Here is what you need to do:
1) Select - Personalize icon that's on the bottom right side of Homescreen. Or you can also select Menu/Settings/Personalize.
2) Select - Lockscreen Option
3) Select - Menu button
4) Select - Select Shortcuts
5) Tap the icon/app that you want to remove
6) Select the app which you want to add from list
7) Click Done
You should now have the icon(s) that you want to use on the lockscreen. Repeat the steps in order to change all the lockscreen apps.
Thanks for that!
I had a bit more of a play around - I actually needed to change to "list" view before it gave me the option to select the lock screen shortcuts, but all good now.
Thanks again!
