Root Changing lockscreen apps in LeeDroid 3.3.3 R5 Data++
A
Andy L
Guest
I've just upgraded to LeeDroid 3.3.3 R5 Data++ on my Desire and applied the Sense 3.0 pack which features the newer lockscreen. The app shortcut on the lockscreen are Phone, Mail, Camera and Messages but I would like to change these - is there any way of doing so?
I'm aware that phones with Sense 3.0 built in would have this option in Menu > Settings > Personalize > Lock Screen > Settings but this doesn't seem to be there on LeeDroid...
5.9 of the FAQ for this ROM
take some time to read thru the rest of it, it's very good for understanding and other troubleshooting
I missed that part of the FAQ but I can't seem to find a Customize option anywhere?
to be honest i used that rom for a while, but never flashed the sense 3 lockscreen
i just knew that what you want is possible, and that FAQ has helped in the past.
keep looking around, you'll find it eventually.
You can't find customize? It's in the menu with a blob of paint icon. You've probably been in it a million times
Yes it's called Personalize but as I said in my original post, there is no Lock Screen option there - only:
Personalize display - Scene, Wallpaper, Skin
Add items to Home - Widget, App, Shortcut, Folder
Personalize sound - Sound set, Ringtone, Notification sound, Alarm
