Root Changing notification bar
skater95
So I'm trying to change the notification bar, from the stock velocity, cause for some reason when I download themes, eventually I can't download apps from the market anymore. So I'm trying to customize it myself. I pull the framework as it says in this guide [Guide] How to change the color of your notification bar / background - xda-developers
I can get the images, and I tried to use images from other themes to replace the stock ones (EX:statusbar_background.png: I use that from another theme and put it on my framework) then I save it, then use adb push, to push the files, afterwards I reboot, and it's still the same, nothing changed and nothing is messed up (Thank God..) So I guess my question is what am I doing wrong? and how do I fix it?
P.S. Sorry for the really long post..
