Root Changing physical keyboard prediction language
Mads_o
Hi All,
I have a bit of a problem with my Desire Z.
Phone is bought in the UK, but I'm moving to Denmark.
I'm aware that I'll have to root the phone to reassign a few keys to add the Danish letters it doesn't contain to the physical slide-out keyboard, but that doesn't help me much, as for the physical keyboard the only prediction language is English.
It doesn't even help me to flash the Danish software version to the phone, as the keyboard layout would be changed completely.
It does seem like a bit of an oversight that HTC hasn't made it possible to change the prediction language for the physical keyboard.
With any kind of mod/rom, is it possible to add a 2nd language for the physical keyboard prediction? Or is my best bet to flash the Danish software, then reassign almost every single key back to it's UK design?
Thanks everyone for your help ahead of time...
M
Swift Key X from the market works to change prediction language of the physical keyboard. Works great. Has language packs you can download, can have up to 3 at a time.
