Root Changing Radios - Question
Dentul
I flashed ROM SHIFTAO5P V1.2 (Great ROM)
Had MR2.0 Radio on my previous ROM and was fine.
I want to flash the recommended Radio MR3.5 .802.
I renamed and sent that ZIP to root and HBooted my TB and here is what the screen shows:
______________________________
MECHA XD ENG S-OFF
HBOOT-1.04.2000 (PG051000)
MICROP-/
RADIO-1.39.00.0627r
eMMC-boot
Feb 20 2011,20:36:02
HBOOT
Parsing...[SD ZIP]
(1) MDM9X
(2) RADIO_V2
Cancel update?
Press <POWER> yo reboot
As a choice, should not I be seeing the PG05IMG.ZIP
What may I not be doing right?
Thanks.
MECHA XD ENG S-OFF
MICROP-/
RADIO-1.39.00.0627r
eMMC-boot
HBOOT
Parsing...[SD ZIP]
(1) MDM9X
(2) RADIO_V2
Cancel update?
Thanks.
If im not mistaken thats exactly what you should be seeing when you update your radio. I believe that the PGO5IMG.zip is translated into that
that is correct... thats exactly what you should see. you were prolly seeing that,as the status bars were along the right had side,checking the file. after it finished,you should see a promt that says something to the affect of "do you want to update? yes volume up/no volume down."
just select yes to update the radios,then press power to reboot when its finished. when you get back to your rom,make sure to immediately delete or rename PG05IMG as it can prevent you from getting into recovery thru hboot.
