Hi all, new here so go easy please.
Right when I want to change my sd card what is the best way?? Do I connect my phone to the computer and copy all the files its shows on my device to a file in my documents, I then remove my sd card and replace with my new one, I then reconnect my phone with my new sd card inside, go to the file that I saved copy all the files and paste to the phone (if that makes sense)
Thanks in advance.
Thanks in advance.
